Kia Carnival / Sedona 2005
Hye to All Kia Member,
Need help for my Sedona 2003,
When my engine running,
My radiator from top to bottom is hot,
But when i drive,
Top of my radiator is cool but bottom is hot,
Then if i speeding my car,
The radiator fully cold from top to bottom,
When i got this problem,
I try go to service the radiator,
But still got same problem,
Still got same problem
Any Kia Sedona User have been this problem?
Can anybody help me?
Owh yar,
By the way my car is Sedona 2003 2.5 engine kv6.
Thanks,
Are_poor18
Have you ever had the coolant replaced and your system flushed? Is this creating a issue like no heat or just something you noticed?
Discussion Starter #3 (Edited)
Already use coolant and tap water,
still get same result,
Radiator hot when engine on idle,
Then when i start driving half of top radiator cold,
When speeding all my radiator cold,
Thanks,
Are_poor18.
Sedona '02
Thanks,
Are_poor18.
Is there any leak? When cold, open radiator cap to check coolant level in the radiator. If coolant is NOT up to the radiator neck, you have issues.
It could be micro leak somewhere so that when hot, coolant goes to reservoir but does not return back to radiator when cools.
Make sure coolant is up to the radiator neck (full) when cold first.
