2003 Kia Rio
Changed the timing belt, water pump, and tensioners on an 03 Kia Rio about 3 months ago. Now it seems that the timing is a little retarded without the A/C on and alot retarded with A/C on. So I took the upper cover off and rotated the crank to check the timing mark on the lower pulley against the timing marks on the cams. My question is which mark on the lower cover does the mark on the lower pulley align with for TDC? Any and all assistance would be greatly appreciated. Thanks in advance and have a great day.
2003 Kia Rio
Sluggish Rio
If I remember correctly, it is the first longest line from the radiator side. I think it is marked with a T or 0 but honestly I'm not 100% on that.
Ok I see the T and the long line, but I was not certain the T went with the long line or the edge of the marking area. Thanks Dsolorio for the reply. If anyone knows for sure, please feel free to post. Looking at making an adjustment to the cam timing instead of removing the lower cover, pulley and belts in the near future, so I would love to use the cover marks to set the crank versus taking it all the way down.
Easiest way to be sure you have the right mark, is pull plug and see if piston is really at top dead center. When it is , that line on the pulley should be right at the TDC mark on the cover.
2002 Kia Rio 2003 Dodge Durango 1993 Chevy C1500
I checked, my last statement was correct. Its the longest line right next to the "T". Along with what Kevster said, pull the #1 plug and stick a long screwdriver down the hole and make sure the cylinder is at the top. If its not, turn it again and double check.
