2005 Kia sedona
I change my timing belt today but i think the crank moved during the install i can see the timing marks on the 4 cams but i dont see how they time the crank , with the plastic cover back on you can see the degrees for setting the timing but when the cover & the pulley is off what do you use ? I have it all back together and it is running a little rough and the check engine light came on i think i am off one tooth on the crank, i did check to make sure nothing was hitting inside the engine before i tried to start it
2004 Carnival, 2.5L KV6 / GV6 / K5 engine
I did reply to one of your other posts on this with a clip from the service manual here, don't know if that's any help. It looks in the shop manual diagram to just be a mark on the sprocket. Also see another one of your posts replied to here.
