They didn't have any nut splitters at the usual spots but I lucked out and Harbor Freight had a very effective rounded nut remover. It ended up being the ball joint after all. Whew.
It would be super classy for them to make a little rubber cap like seen on brake bleeder screws but to cover the nut and any exposed threads. It took considerable effort with an 18" breaker bar and that was after cycles of heat, WD40, hammer blows, and wrenching.
Unlike the tie rod end that required only a few good whacks with the hammer to dislodge, the ball joint had to be pickle-forked with multiple hard hits. I'm fairly certain it was the original because the other side was a nice Moog with a grease fitting.
Now back for alignment check and hoping to convince a shop to put on some used tires I have DOT date coded 9 years ago. Any suggestions of places that aren't fussy in the Ann Arbor, MI area? Thanks
