2005, model V6 3.6lt 4wd kia sorento
Please where does engine temperature gauge on dashboard suppose to be when engine is hot with AC on?
Discussion Starter #2
I just bought used Kia sorento 2005 model and each time I drive with AC on the temperature gauge needle will be on the tick middle line on the dashboard. Is it ok or where is it suppose to be normally with Ac on? I need your opinion please.
Under normal temps the middle of the gauge is fine. Check your coolant level to be sure it is topped off.
The temp gauge is not very accurate imo. Having said that, the a/c function does automatically cause extra radiator fan to come on to maintain temps. Mind you, if that flag is correct, your ambients may be a little higher than the majority here.
