My sad tale begins...
Today I met 'my' EX-T for the first time. The car was a locate from a dealer 70 miles away and was driven here. Driver told my salesman it pulled. My salesman, having been fully apprised by me for weeks about issues, got it in for PDI immediately. He knows I'm technically versed about the issues (pull left and turbo reflash) and let service know that too.
After 1 1/2 hours of waiting, he tells me the asst. svc. mgr. drove it and pronounced it fit. I said to salesman to come with me for my test. (No buying yet).
First thing I did was check with my gauge and found all 4 tires between 41 and 42psi. They were relatively even. I shut the car and gave him a crash course in suspension geometry and that everything starts with the tires at the correct factory spec, which is 33psi all. It obviously had been no where near an alignment rack.
He begged me to drive it anyway because "it's been fixed".
It promptly pulled left out of his lot. I then took it on flat and crowned roads, slow and moderately fast. I drove in right lanes, on-coming lanes and city streets.
I showed him how it pulled while accelerating, coasting and at steady throttle. When he stopped shaking, I then asked him why the mgr would attempt to BS me. He said let's find out-you talk to him and I'll verify everything I saw you do.
Well, Mr. mgr could not account for the over psi tires and I took him outside to show him. He said "Hmmm".
I then told him PDI for my car (1-11 build) should include TSB's 069 and 032 checks and corrections. He said they did the 069 (turbo reflash) and showed me his house ticket documenting that. But he never heard of 032-the pull left. I showed him my 12 page copy and he punched it up on his compy. Sure enough, there it was and he'd never seen it and thought it new. I said it was about 3 weeks old.
By now he's really paying attention to me and not just trying to send me home as a know-it-all, BS customer. I said I would leave the car overnight, (it was 5PM and techs were fleeing) and expected the car to get the rack for a check and corrections. I would go back mid-day to retest and discuss the settings.
Thanks to fellow member DM who posted his specs which corrected his pull, I told Mr. mgr. I might want the specs changed to my preference after my test. He agreed. I told him I wanted more caster on left than right, more toe-in left than right and a hair less camber in front. Also less toe and camber in rear. He volunteered a check of the tires for conicity and balance-although it had no vibration.
So rather than trying to tell everyone else what to do, let's see if I'm smart enough to get my own problem fixed by folks who are apparently less motivated than we would all like them to be. They know tonight that the BS to me ain't gonna work and ended today.
Like DM and others most helpful, I will continue to post here wherever this may lead.
On a positive note, the car was really nice to drive excepting the problem and looks just as I like it in SWP and gray. I have this burning fundamental question:
WHY IS KIA (AND PARENT H.) CONTINUING TO LET CARS OFF THEIR LINES WITH A MAJOR CHASSIS ISSUE SUCH AS THIS?? THEY DEVELOPED A TSB FOR THE FIX BUT DID NOT CORRECT THE FAULT AT THE ASSEMBLY POINT??? I can only ask "WTF'? And I'd really like to know what's causing this.
More tomorrow.
