21 - 40 of 44 Posts
Discussion Starter #21
7/25/18 UPDATE:
Well the spectra is sitting at 127k miles now Synth. oil change is working well. BUT daughter was home for an afternoon and said things didn't seem right with the steering, and was making a noise(growling) and thought was from the R rear.
Well I looked the car over and sure enough it was a R front wheel bearing going bad! Done LOTS of the type design for other makes(press in 1 piece bearing), so early next week will be doing that job for her. Just odd that it is this far bad sounding in less than 2k miles of use, as I test drove her car after doing the oil change and all was good. She is doing MINIMAL driving till I can get to the task, as she is 50 miles from home now having moved out on her own!
Discussion Starter #22
08/01/18 UPDATE:
OK so after starting the RF wheel bearing replacement on 07/31, I finally am finished with the task there! I did it "on the car" with my tooling that I have had for other cars with this type 1 piece press in bearing. NY RUST was horrible down to removing the snap ring retainer! We shall see how this holds up...this turned into a job that even I would not want to do again!
Much quieter ride and steering is not "wonky" anymore. BUT there is a slight bearing hum when making curves in the road. I suspect that another bearing position is going bad also. BUT am TOO "wrung out" to check further, AND have to deliver the car back to the daughter later today!
Discussion Starter #23
BUT ....Looks like I am going to be doing the LF bearing soon also! Not bad for noise but it can be heard,at least there isn't a bunch of "wobble" from the ball bearings like the RF had! Car is back with daughter and she is going to check her work schedule and weekend plans for being able to give it up again for the next bearing work and a NY State Inspection!
Discussion Starter #24
Well, Looks like the weekend of the 18th this month will be the work time to do the LF bearing. daughter has the Saturday off and has the Monday off also and will come out and spend the weekend here! Then a Monday morning appt. for NY annual inspection, all is good otherwise and just a "formality" to get the new sticker!
At least there is NOT a speed sensor in the LF knuckle to worry about unlike the RF one, which I could not get to budge when doing that bearing!
Discussion Starter #25
Well the LF axle bearing got replaced yesterday afternoon, Went quicker and smoother than the RF did. Got it's annual inspection, with flying colors and was delivered back to the daughter 50 miles away. Was a nice comfortable and QUIET ride.
The little car is doing OK for 128 k miles on it!
Glad you got the Spectra fixed and inspected :)
Now you got me worried...My 2008 Spectra SX has 120k on the odometer but is quiet for the time being :)
Just finished a 2014 Optima LX for my wife...Another "salvage" car... It has 51k on it and I bought it for $2250 and found most nose parts at the Cleveland pull-a-part off of a 2011... We have $3500 including painting the hood and bumper cover in a 4 year old car that looks like it was just built ...Not bad...
Discussion Starter #27
So that is why you have been MIA for a while...LOL;)! Hope the "new" Optima serves you well.
Front axle bearings going bad does NOT "surprise" or anger me on ANY FWD auto...it happens, especially in our rust belt area. Most bearings that I have done though in the past and with our Neon, the bearing comes out from the knuckle from the drive flange side. NOT so with the Spectra, just the opposite and makes things a bit more awkward to do. Daughter was not home at the time we delivered the car, so waiting to hear from her of the noticeable ride noise REDUCTION.
When all this started happening, she was asking if it was time to "trade it in"...I told her that as long as I can do the labor, and parts are cheap enough that the body and suspension seem to be in good shape for another few years..IF the RUST GREMLINS don't start attacking too harshly!:laugh:
Now I'm working on my Daughter's Gold 2008 Hyundai Sonata... We got it 3 years ago right around Christmas.. It was "T" boned on the driver's side and both doors and the rear quarter panel damaged... Because it was winter I threw two burgundy doors on it with a lot of washers to shim the doors out so she could drive it... The passenger fender was also damaged ... It had only 38k miles on it.. (it now has 56k Miles) Well time has passed (she couldn't live without her Sonata) and it needs some TLC.... Rear tire leaks, door locks have problems, and it badly needs the oil changed (10k miles on conventional oil)... She's 120 miles from home in Columbus, Ohio and on her own trying to pay off her student loans ($80,000) and has little money to spare...
This Monday I by chance found a Gold 2008 Sonata at my local "pull-a-part" with two perfect driver's side doors, and also the passenger fender... I also found the driver's side door sill and the "B" pillar covering... So I'm in the process of making her Sonata pretty once again... My willow tree and a cable winch has the B pillar back where it should be... Now I'm gonna start on the rear quarter panel just behind the rear door tomorrow and replace the burgundy doors with the gold ones... I have all read replaced the fender with the gold one so the passenger side is perfect once again... I only have three more cars to work one after I finish her car...
So I am sorta busy :)
Discussion Starter #29 (Edited)
Well good wishes for your daughter! Seems mine is in a similar position with college loan repayments! I will do most anything mechanically on cars to get and keep things running right, BUT beyond hanging a door or fender type body piece...I detest doing body work!
I did get thanks from my daughter the other day about the last work being done...Said it was a much more pleasant sounding ride home from her "high stress" employment and didn't need to crank up the audio volume to hear her relaxation tunes during her short 10 minute drive! $50.00 for parts was A LOT cheaper than to have a dealer or shop up there do the job! YES she pays for needed parts, but I always try and get them at the best prices, unless in a HAVE TO bind!
Discussion Starter #30
Here in the USA, it is the start to the Labor Day weekend(TGIF)! Daughter will be coming home for the holiday when done work on Sat. This will give me (as a watchful over cars dad) a chance to "look things over" on the little Spectra. NO calls of complaints from her, but I'm SURE that at least the washer bottle will need REFILLING again!...LOL :)
Just fixed a 2008 Hyundai Accent that was overheating.... Turned out to be an out of spec thermostat...
The thermostat is rated for 198 degrees F ...Never seen one this high in temp... The old one was allowing the temperature to rise to 206 degrees and that threw a check engine light... The car would run fine IF the air conditioning was on (both fans running) ...
Then I fixed for the same woman a 2008 Ford Explorer XLT that needed rear brake pads...
Then I got a call from her grandson on his 2011 Turbo Hyundai Sonata 2.4L GDI... It was spewing gas under the hood... It has a bad "high pressure fuel line" going from the high pressure fuel... The line end attached to the HP fuel pump started leaking... The pressure within that line is over 600PSI... Tightening it made it worse...so I ordered it from Ebay for $22.00... The Hyundai/KIA dealership wanted $49.00... so that will be repaired in 4~5 days....
Tomorrow I'm working on a 2004 Honda Accord V6 with leaky valve cover gaskets and spark plug gaskets...
I did get the body work done on Mary's 2008 Hyundai Sonata, but still have to rotate tires, attach the driver's side front fender on the bottom (both bolts snapped off when I removed the fender to gain access to the front door hinge bolts... It really looks good and I'm sure she'll like the improvements...
Just not enough time being retired :)
Discussion Starter #32
BUSY,BUSY,BUSY!!!...LOL Actually I am going to try and relax it this holiday!
Discussion Starter #33
Daughter and Fiance made it out last evening and are spending the day today.....They came out in his car!
Guess that I will get to RELAX this weekend from "playing" with the cars!:laugh::D
Discussion Starter #34
Daughter had today off from work and came out to visit, along with a dentist appt. She has been doing mostly short 12 mile drives and has now reached 2,500 miles since doing last oil change to synthetic 10w30 Valvoline high mileage oil. I only had to top up 6 ounces of oil to bring it to the full mark on the stick. VERY happy for only that much consumption on first use from conventional oil, with an engine now at 128,500 miles on it! Oil still looks very clear and will have her go to 6k miles before the next change to be done.
NOTE: It is still a hassle having to go thru all the steps needed to open that darned HOOD!...LOL ;)
Discussion Starter #35
WOW, I missed my "anniversary" here! Two whole years already from 9/23/16...and I have NOT had any of my threads deleted or been BANNED from the Forum here! Hope that trend continues.....
Discussion Starter #36
Well, here it is DECEMBER already! With the Spectra now residing in a much more suburban area with lots more traffic to contend with, my daughter has decided that she wants full snow tires on her car. After her spin out/partial ditching from sloppy country road last year, she wants to feel more "secure" among heavier traffic there. Prices were rather high at places near her, as she tried to get the task done on her own at over $100.00US/tire! I did some calling to my sources and got her 4 Cooper Evolution Snows at $75.00 ea. And will get them mounted on 12/12. Total cost will be right around $380.00 US! Daughter is happy and making the trip out here for that kind of savings, plus then her still good "all seasons" will be here for us to store for the winter for her as her apartment has NO ROOM to do that!
And the Spectra is still "rolling along" just FINE with no concerns!
Discussion Starter #37
Well, the SNOW TIRES are mounted on the Spectra. And daughter very happy for price and the aggressive pattern of the tire compared to the "all season M&S" tires she's had on it! We have bare roads right now , and she called to say that they ran well and were quieter than the last car(98 Escort) with full snows!...HAPPY ENDING! :)
Discussion Starter #38
Well, We heard from the daughter when she got home from work yesterday. They got hammered with Lake effect snow (we got nothing). She reported that kia is starting up well in the near 0f weather(parked outdoors), and that the new snows are doing a great job of gripping the road with few to no issues of control problems...Her work parking lot is well plowed, but is always like a sheet of ice, so she says that the car slides a little but easily handled! Out on the roads she says she feels much more confident with the handling of the new tires and has had to do "some maneuvers" to avoid other cars that were having handling "issues" from the weather! She says that it's a big change from RURAL driving scenario's to more URBAN driving and watching out for much more vehicular traffic!
Discussion Starter #39
Well, as I posted a reply to a members concern of belt squeal on an 06 Sportage forum page...
This weekend I have the car from daughter and today I took the alt/H2O pump belt off and checked for possible bad Alt. bearing(It's FINE), re installed and adjusted the belt(was good before), and then flushed out the 10 year old power steering fluid. Going to let it sit till Sunday morning and see how things go for initial start belt squeal and hard P/S on first wheel turning at start up.
Been about 2 months since I did belts/ timing belt kit(with H2O pump)/ Lube, oil, and filter. Has used NO oil and all is in good order!
Would have done this a lot sooner, but 50 miles away and apartment complex rules state NO auto work in the parking area. Daughter still loving her "Mia Kia" ride!
Discussion Starter #40
SUCCESS!!!!....While the mornings dew was still heavy(7:00 a.m.), went out and started the little car and NO SQUEAL and NORMAL steering effort! :)
Daughter will be VERY HAPPY when she comes to get her car!
Odometer now at the 134,000 mile mark and doing well in NY's RUST BELT area around Buffalo,NY!
21 - 40 of 44 Posts
