Hi guys,
We have a couple clunking/popping noises in the front left. Been an ongoing issue with this car since new. Under warranty Kia kept saying it was all normal and couldn't find anything wrong. Even when I went for a test drive with the mechanic and he heard it, they ended up saying it was nothing. Funny bunch of folks.
Anyway, I discovered the sway bar link was toast so replaced it. Still a bit noisy, sounds like the strut is worn out. All other mounts and joints seem okay. Strut top mounting nut is tight so it's not that issue.
Anyone use those "easy struts"? I do have the spring compression tools so it wouldn't be a problem to change just the strut and re-use the spring. I'm wondering if there are any recommendations from owners regarding a need to replace the spring too. I used to always re-use strut springs but cars these days seem to chew through parts and/or parts are not as quality made as they used to be. We already had the rear springs replaced because they were "sagging".
So, anyone recommend replacing the strut spring along with the strut shock? Any tips on good deals through the internet marketplace for these parts, brand preference, etc? Keep in mind I live in Canada.
Thanks,
Curt
Thanks,
Curt
