I have a 2002 Spectra with about 120,000 miles, auto trans, standard stuff. It has always run well until yesterday AM. The car would not start, it would turn over very well which is normal but no "Fire in the hole".
It does not have spark most of the time every once in a awhile it will pop or poof.
The plugs are always dry and I cannot hear the fuel pump run at all. I pulled up the rear seat and checked the connection and to listen. The connections are good but I can not make the pump make "running" sounds no matter what I try, cranking or just cycling the ignition key.
We placed some gasoline in all four plug holes and it produced nothing at all.
The radio and Clock do not come on.
all the fuses both under the hood and inside the car have been checked for continuity with a meter, they test good.
Everything else seems to be working as it should. the lights, inside and out all works as expected,
Any help will be greatly appreciated.
Brad_cad
Brad_cad
