2012 Sorento LX
Hi all,
In the past month, my 2012 Sorento LX with ~24,000 miles (purchased used at 10k mi) has started making what I can only describe as a "hollow chirping" noise when the air conditioner is running.
The sound seems to be coming from the glove box or center console - definitely on the passenger side of the vehicle - and sounds similar to the sound you'd make if you flicked the side of a big PVC pipe with your fingernail or dropped a water droplet onto the bottom of an upturned 5gal bucket.
It ONLY happens when the A/C is set on fan speed 3 or 4, and is aggravated upon initial acceleration from a stop and when turning the vehicle left. It'll happen 2-3 times upon initial acceleration and then again every 3-4 seconds (varying intervals.)
Since I'm second-owner I don't have the bumper-to-bumper warranty, and before laying out diagnostic/investigative $$ I wanted to know if anyone else has experienced this problem and/or had it repaired?
Thank you so much! :)
White 2012 SX AWD
Not sure, but I'd guess the drain is clogged and condensation/water has built up ad that's what you're hearing.
2013 Sorento, Suzuki V-Strom
The clogged drain is a strong possibility. Does the car leave a water puddle after you park it when the A/C has been running? It should.
I haven't slithered under mine to find the drain line. Can anyone guide AH into finding his so he can try clearing it?
2011 Kia Sorento
Hi all,
I've had the same thing happen, as well as a howling noise that is intermittent in the winter. The dealer advised that it may be a variety of items in the AC system failing, improperly lubricated or just plain noisy. It still works so I haven't investigated further.
