Having a heck of a time figuring out what's going on with this car. It's a 2008 Rondo with the four cylinder and an automatic.
It will crank like crazy, but never even thinks about starting. Basically acts like you're trying to start it with a non-programmed key. But there is no immobilizer light.
The reason I say it's not fuel-related is because, well, it's everything-related. The car ran, and then it just died in traffic one day and would not restart.
There is no fuel, no spark, and as far as I can tell...no ECM. I cannot connect to it with a generic OBDII scan tool. All the interior and exterior lights, the stereo, the windows, ect, work fine.
But when you attempt to start the car, there are NO relays being energized in the box under the hood other than the starter relay.
I've searched and all the info I can find always seems to just talk about problems with the fuel pump, the fuel pump relay, or one of the other relays. I can't find anything relating to every single relay (except the inexplicable starter relay) not getting turned on.
There is power to the box, and I have checked all the fuses for power on both sides. Nothing is blown. I haven't pulled the box to check the ground(s) yet, but I don't see it just randomly completely severing itself, and I don't see why the starter relay would still be getting powered up.
Is the ECM dead or am I missing something here?
