1 - 8 of 8 Posts
2005 Kia Spectra LX
Alright so I've had my fuel injectors cleaned professionally, gotten the spark plugs re-programmed, and replaced my air filter, and I'm still getting around 15mpg tops. Any suggestions on what may be the problem?
1995 Procharged Mustang Cobra, 2021 Sportage EX
Well, I'd try a fuel filter. Could be cloged.
2005 Kia Spectra LX
Any other suggestions? I honestly doubt it's the fuel filter as it has pretty low miles still.. but will check out asap.
I also heard of resetting the ecu since I already changed the filter and re programmed the spark plugs? How does that work though?
To rest the ECU you need to disconnect the battery for about five minutes, then pump the braks a couple of times, this is to make sure there is no residual current. Hook the battery back up and go for a drive. This sets the ECU back to the factory map. Drive as you normally would and the ECU will start to adjust itself according to the improvements you have made.
2005 Kia Spectra LX
I just reset the ecu, hopefully my gas mileage will improve but I really don't think it could've cost that bad of gas mileage, could it? I see people getting like 30mpg and above on their Spectra's and I'm getting 15. :/
2005 Blue Kia Spectra5 and a 96 Turbo Honda civic and a 99 subaru outback with a 2.5 rs turbo motor
sorry to bust in but where is the fuel filter located on this car.
05 spectra
It's located within the gas tank.. It surrounds the fuel pump.
ohh ok. cause i know most american cars fuel filter is in the line itself. well 2 filters one in the line and the other in the pump.
Thanks dave. I might need to replace mines since i never had since i got the car. im also replacing my trans fluid and filter tonight also. i already put 30k in 1 year since i replaced my trans.
1 - 8 of 8 Posts
