hav a ceed 4 aug 2012 diesel with sat nav. when i turn radio on when the ignition is on it only stays on for about 5 mins,save battery i presume when it goes of you have to put ignition on then off before you get another 5 mins. can the length of time be changed so i can let people listen to radio when im out the car
pro_ceed 1.6 CRDi 66kw (2008)
Shouldn't you just push the knob to switch it on while the ignition is off ? This should keep it running.
Cee'd 1.6 GDI in Space Blue
Mine turns off as well after a few minutes, even if you turn it on after pulling the key out of the ignition and you turning off the screen. I too have the 2012 model with satnav, so I don't know how how long the basic radio stays on.
Mine (2012 Ceed 1.6L petrol with nav ) runs the radio with engine off for about 20 min, than come up with the attached message. However I already know there are some issues keeping the battery fully charged (causing the ISG to DE-activate)...
