Look at this kia site free to join but works best on internet explorer. https://www.kiatechinfo.com/Index.asp
click on year, model, engine. Them select install them topic.
Uhm no I def know how to raise a vehicle but since its the back shock I can't raise it by the frame because the coil might fall out if I take the shock off ;-) I just need to know for sure if I jack it up on the rear differential Maybe I should have worded it different.
As stated in your other post. Yes the rear differential or if you to do one wheel at a time jack it up on the axle tube an support.The weight of your car will keep the spring compressed. Than remove the shock.
