2016 Kia Sportage
Is there a place that I can order a new steering wheel emblem for a 2016 Kia Sportage? I was told by the Kia dealer that I would have to order an entirely new wheel (or airbag, I can't remember exactly), but I have gotten some bad info from them in the past so I figured that I would ask you all. Also if I can, is there anything specific that I should know when installing it? Thank you.
2017 Kia Sportage
You can get a "K" emblem (which is what I got), from eBay. I changed all of my emblems to this.... Be careful of the quality. Loden is good quality but slightly more expensive. Be sure the measurements are right for your 2016.
2016 Kia Sportage
Right on, thank you. Is there anything specific that I need to know about changing it out?
2017 Kia Sportage
Mine were overlays... You just clean the surface of the one you have with a little alcohol or glass cleaner to get a better stick. The emblem has self adhesive on the other side. If you're slow, it should take about a minute....
2016 Kia Sportage
I might need to completely replace mine, I'm not too sure what happened but the previous owner was pretty rough on it. Do you think that I could take the old one out and put an overlay on, or do you think that an overlay would stick if the old one is really caved in?
2017 Kia Sportage
The overlay is pretty sticky, so even if the original was cracked, as long as there is nothing sticking up from the surface, this should cover it just fine. I don't think the overlay will fit if you remove the original. I've had mine on for over three years in the Vegas heat, and it is just fine...
