1 - 1 of 1 Posts
Sorento V6 AWD 2011
Here is the website where you can get the kit made by axxess
Axxess Interface - Steering Wheel Control
I replaced my unit with double din JVC unit and used the steering wheel kit. Works good, the only thing it must be updated with newer version if you still want to use your call features (Answer/End call).
In most cases it connects with 3 cables.
Things to watch for, when you wire the cable on pin 5,6 on the Sorento plug as stated in the instructions, for Sorento 2011 it is blue and gray cable. The diagram is a bit confusing and is upside down. First i cut the white and gray cable and tried to figure out why it does not work, almost gave up...
1 - 1 of 1 Posts
