1 - 8 of 8 Posts
My steering wheel makes a knocking noise when I turn the wheel to the left or right. The sound only happens as you begin the turn, and only happens only once. until you turn the wheel back the other way (then only makes the sound once, again). I believe this is the same problem experienced by the 2015 Optima. Anybody else had this problem?
eg.
South Carolina, USA
SORENTO EX, 2014
I'm not a mechanic, but my experience is tells me tie rod end or CV joints How many miles on your vehicle, any hard driving (dirt roads/ uneven pavement)?
Sorento SX FWD 2015
Is the noise inside the cabin (steering wheel/power steering motor/coupling) or outside in the steering linkage ?
See first 15 seconds of this video for inside knocking example.
Please add your year and model as it helps up assist you..
Sorento SX AWD 2015
Its the rack and pinion system which includes the tie rod ends. Being that loud its definitely gone if its knocking when you turn the wheel left/right to the point of resistance and a bit more each way. Common internal failure for some reason. I caught minne early when it was faint and got a new one installed. They're not cheap.
eg.
USA
1 - 8 of 8 Posts
