97 Sephia will only start when a code reader/scanner is attached! When the scanner is not attached, the engine turns over but has no spark. Also, while running (with reader attached) no codes are detected. The check engine light does not come on either.
Has anyone had this happen and/or any ideas about what could be wrong. TIA
98 Sportage/ previously 01 Sportage
If you found the answer to this, please share with us!!!
