Sportage 2.0 Ghia
Failed MOT with every dust cover split. Need to replace the one on the stabilizer swivel joint, which is mounted on the end of the lower Drop Link. Is it necessary to remove the Drop Link from the suspension forks / lower control arm, or can the swivel be removed from the link in-situ? Any advice welcome, especially if it saves removing the link, as I fear this will lead onto re-bushing. All a bit much for a dust cover! p s all terminology as in the kiatechnical site.:huh:
Sportage 2.0 Ghia
Thanks Philip, had a look at the supplied link. As far as I can make it out, only CV covers are available. As I mentioned, this is a swivel joint dust cover, for the stabilizer bar, also known as the anti-roll bar in the UK. Cheers.
