Wow. What an ignorant diatribe. First, the redline on the KIA engines is very conservative. After all, they are guaranteeing it for 10/100. You will harm nothing by holding your foot down and letting it shift at 6000 - the engines can most likely do 7500 with no problem. Would you drive like that all the time? No, common sense has to prevail, but it is a very sporty vehicle even without the turbo. Obviously you have never pushed your SX anywhere close to the programmed limit or you would have known that in manual shift mode the trans will upshift just like it would in automatic mode under full throttle when the redline is hit. Honestly, you need to exercise that thing once in awhile. Do I drive around in manual shift letting it hit the limit, rather than just driving in automatic mode? No, I don't, as a rule, but I have experienced the upshift in manual mode a few times. The first time I didn't expect it, but upon reflection it was completely logical that it would.
BTW, the question 'Can you exceed the redline?' was rhetorical - obviously you can't. You owe it to yourself to experience all that the car's programming will allow, which by no means is 'racing'. 'Racing' an engine means gunning it in Neutral. Next time you're merging onto a fast road, let that thing eat! I can't believe somebody has a turbo and has never just stomped it and let it run, at least in the first three gears.
You have to realize that what we're talking about is within the parameters of normal operation, in that the car has a certain potential for acceleration that is controlled by it's programming, and you can't exceed those parameters without changing that programming or otherwise making modifications that would void the warranty. Plus, the car has a data recorder, so let's say I'm passing on a two-lane road under full throttle and something breaks - the car would be repaired under warranty because the acceptable operating conditions were not exceeded. The vehicle is expected to be able to perform at maximum-allowed levels for the duration of it's service life - not all the time, but every so often you may have the need for that maximum performance, and the manufacturer is guaranteeing it will be there by setting the parameters conservatively low. Imagine what even the EX could do with no restrictions, much less the SX! Now that would be more like racing and most likely would use up the car before it's time.
