Hi all, seeking some help, the windscreen washer works for a few seconds then totally dies, any suggestions please.
Thank you
Gen 1 Sportage
Blocked filter/gauze on the pump inlet in the washer bottle, pull pump out, clean the gauze and flush the reservoir, then refit the pump, being careful not to push the rubber grommet it is located in, into the reservoir, lube it with fairy liquid or similar to aid refitting.
