Hello,
I replaced the Vehicle Speed Sensor, but the speedometer is still not working. I ordered part #0K2A117400 after contacting Kia to verify the correct part. I installed it fairly easily, but the speedometer is not working. With the ignition on, I checked the voltage coming from the 3 wires to the VSS and I get 14 volts out of one pair and 10 volts out of the other pair, so it seems like the wiring is ok going to the VSS. I was wondering if maybe I got a bad replacement VSS so I ordered another. I tested both new ones and I get resistance, so I think they are ok. I’m guessing it is a problem in the cluster/speedometer. Does anyone have more suggestions for testing?
Thanks,
Chris
2014 Hyundai Veloster Turbo / 2001 Kia Rio
any chance you could find a different cluster?
