1 - 9 of 9 Posts
2005 Kia Spectra5
maybe 5 1/4" they are crappy compared to the front speakers and have no type of enclosure.
Does anyone know if 6.5s will fit in the front door also? I already have one blown speaker, so I'll be replacing all of them soon, but need to know what will really fit...
Hi.
I think it fit too ,but not all the models ,it depend on the screw holes .
But any how if the screw holes don’t fit .you could make it by yr self.
Actually, the rear spaekers in the 2005 Spec5 are a little used size: 5X7 inchers. It's slowly growing in popularity and your starting to see more Hyundai/Kias and Chrysler products with them. Still not many available through the aftermarket, though. Crutchfield does have a variety, and yes, the fronts are 6 1/2"
2005 Kia Spectra5
Actually chasaf2004 this thread is 16months old and you are wrong. The rear speakers are 6.5" not 5x7".
I can assure you that you can FIT 6.5" speakers in all the loactions. BUT for the doors they need to be SHALLOW DEPTH speakers, like Infinity's I put in my spec5. I just used the shallow ones all over since I wanted a matched set.
In the front you will need to be handy with making your own mounting brackets in order to get them good and secure, otherwise they will mount but not very well. I would recommend 1/2" MDF which will give you clearance between door skin and the window will have plenty of room. You will also need to cut down the plastic on the inside of the door as it may hit your speakers, Dremel tool baby.
For the rear speakers they should bolt right into the stock plates, I did have to make new pilot holes but no biggie. It's easiest to remove the whole speaker plate from the car to do the work, just a couple of bolts and it's out. Again you will need to grind down the plastic on the cover pieces, I took everything off except the very outer screen. BE CAREFUL these pieces are very thin and a little slip will leave you with a hole.
As far as wiring goes I would recommend simply soldering directly to the speakers I ordered the adapters from crutchfield and they did not fit.
2005 kia spectra5
if you check out scosche.com under the necessaries PDF file on page 148 part number SAKA656 there is a front door speaker adaptor made for 2005 and up spectras the kit fits both 5.25 and 6.5 speakers
1 - 9 of 9 Posts
