1 - 11 of 11 Posts
Have you checked your air presure on all the tires??
With non-OEM rims and tires the TPMS "senders" may no longer be there.
The were mounted by the stems. to the old rims...
If they are gone just pull the dash cluster and remove the TPMS bulb.
Just like any car without TPMS...YOU have to watch the tire pressure(s)
Yes, you could buy new TMPS sensors and have them installed in your wheels. OEM Kia tpms sensors have a list price of $56.00 each. I could sell you them for $43.00 each. You can PM me if you want to get them.
But 40 PSI may be higher than the "standard" range for KIA TPIS senders...
and may send errors for over-inflation...
I'd believe just removing the bulb/lamp and checking the tires is the best path to follow...
05 Kia Sorento LX 4x4
Now I'm left to ask what TPMS light? The one that uses the letters "TPMS", or the one right below it that is the tire profile with the "!" in the middle.
If it's the TPMS, than the sensors are absent or non-functional.
If it's the (!), than it's actual pressure (over/under).
You said "If it's the TPMS, than the sensors are absent or non-functional."
Read the original post...He got the car used with 17" (non-stock) rims and tires..
2006~ Spectras came with 15" steel and 16" alloy rims and tires..
I'd bet that none of the pressure sensor senders are present and the TPMS light is on.
Actually was a reason for asking ;)
He mentioned that the tires were inflated to 40psi, which would trigger the over/under warning (!) if the sensors were in fact moved to the new rims, would it not?
2005 Blue Kia Spectra5 and a 96 Turbo Honda civic and a 99 subaru outback with a 2.5 rs turbo motor
i would think lower profile tires would need higher psi and if the old factory TPS is probly set to 25psi or less for it to be trip.
1 - 11 of 11 Posts
