1 - 13 of 13 Posts
· Registered
2006 Kia Picanto
how many inches are the speakers of a picanto or who many inches speaker can fit in the door panels???
so to change them because they suck (poli moufa)<- the greek translation
· Registered
2006 Kia Picanto
i don't want to cut anything the only thing that i want is to put new speakers with the excact size with the old ones but with a better quality in sound like pioneer, focal ...........
so , how many inches excactly they can feet in there ????
· Registered
i know the rear speakers are a nightmare, apparently the picanto takes a 7 inch speaker and conventional speakers only come at 6.5. I had to drill new holes in the door to fit my speakers. Kia wanted £36 per speaker !!!!!!!!
· Registered
2006 Kia Picanto
Discussion Starter · #10 ·
Originally posted by aface@Mar 22 2005, 12:35 PM
cut away some white fucking plastick and you can fitt a 6,5 ;)
where is that white fucking plastik, inside the door or is it the plastik outside that covers the speaker???
it is difficult to put JBL - GTO 6526 speakers in my picanto by my one or i shall prefer an expert to do my job???
· Registered
look if you take of the door cover you will se a BIG white plastik thing that holds the speaker and move speaker out a bit so the window dont touch the speaker...
take of the white fucking plastic and start cutting...if you have a dremel if would go easy.
i had to cut of a dirt shelter to to fit my jbl speaker
the orginal mounted spekar in my picanto ex was 4 inch and 25 watt maximum...really shitty
· Registered
no need to cut anything actually... a 5 1/4 speaker fits the front door speaker mount perfectly! And you can get seriously decent 5 1/4.. try JBL, Sony or MB Quart.
The rear speakers are different though as they don't come standard in the Picanto.. a good sound shop should have plastic mounts designed to fit any door speaker pod that will fit... these standard mounts will accept 5 and 1/4 inch and 6 inch speakers.
1 - 13 of 13 Posts
