Hello,
somebody broke my left mirror glass and I got a replacement. However, how do I put it in? Do I just press it inside the circle? I don't want to break it.
05 Kia Sorento LX 4x4
There are several ways to replace the mirror glass. The easiest (and usually cheapest) is a stick-on overlay. Just take the paper off the back and stick it over the existing, but broken, glass.
There are also factory replacement glass pieces, that mount to the disk inside the mirror housing (the part that moves to adjust the mirror). Follow the directions that should have been included with the replacement glass. Some are adhesive, others have "clips" or "brackets" on the back.
The most expensive way, is to replace the whole housing, and may require removing the interior door panel to remove the bolts holding the housing on.
