1 - 7 of 7 Posts
2005 kia sorento
I bought Sorento 2005 couple of months ago gradually I noticed that it's not accelerating as it have to be .if a push the accelerator to the floor it just reached 4000 rpm and gear changes .in the manual mood same thing .check with obd tool this error code showed up . Is this the main reason ?
2005 kia sorento
P0716 ... That's what it says input/turbine speed sensor ''A'' circuit no signal ...
Don't know what it have to do with the jets 😂
If, as originally stated 'no signal', it is likely either the sensor not giving an output or the tcu not receiving an input fom the sensor (defective connector/wire?). I would imagine that the only way to find out would be some diagnostics to check the signals (whatever they might be).
2005 kia sorento
Discussion Starter #7
definitely i will do that and update you later.
1 - 7 of 7 Posts
