*Price Drop* Kia Rio(UB)12-17 Godspeed MonoSS Coilovers w/ xtra Struts & Strut Mounts
These are Genuine Godspeed MonoSS Coilovers for the 2012 - 2017 Kia Rio. The coilover installation on the rio can be tricky and usually the coilovers don't come with all the parts necessary to do a true swap but these coilovers also come with pre-installed strut mounts for an easy swap-and-go installation. The struts currently installed are stuck on the hardest setting but if that's not to your liking they will also come with brand new 100% working extra strut replacements (See Picture).
They were tracked once and performed wonderfully, other than that they have been used under normal driving conditions (Outside of the new struts, those have never been used) for approximately 10,000 miles. The Rio pictured has them installed to get an idea of the drop, they go much lower.
Features:
Spring rates: Front: 6 kg/mm / Rear: 4 kg/mm
16 precise levels of damper adjustment
Polyurethane bushing (if applicable)
Monotube shock design
Anodized shock body
52mm carbon steel shock body with a performance internal piston
Independent ride height and spring preload adjustments
Race shock oil with a high viscosity index
Spring Front Rear
Rate(kg/mm) 6 4
Length (mm) 180 170
I.D. (mm) 62 62
Camber Plate No No
Prior to installation, verify all hardware and properly preload suspension to 10mm.
PRICE IS $425 with Free Shipping to the Lower Contiguous 48 US States
I am willing to ship beyond those states but the buyer will have to pay shipping.
