Hi, I'm new to the forum but couldn't see anything on this. I can't fit my regular snow chains to the Carens, as the Control Arm (I think it is), which sits below the drive shaft means that once I've passed the chains behind the wheel, I can't pull the two ends high enough up to join them together around the front. Has anyone experienced this?
I guess I need £300 chains that fit on the outside only rather than £50 that are more standard, but wanted to check first!
Thanks,
Alec.
where are you located that require chains on a vehicle such as the Carens? Many places they are illegal. Get a good set of snow tires, forget chains, if you need chains you shouldn't be driving in those conditions.
