1 - 7 of 7 Posts
2012 Optima EX, 04 Sebring. 98 Ranger
We have a EX with premium and tech packages. It has the regular stick with the suto shift, no paddles. Recently I took it for a spin while the wife was working and I tried the stick shift. pretty impressed but I cannot seem to go into 6 gear. It goes through the numbers well and you can seem them up on the display but at 5 it just will not go any further using the manual shift. Is this normal. I would appreciate it if someone gets time and can try this. I am wondering are the rpms to low or to high to engage into 6 th gear? Thanks for any feed back.
2011 Optima EX
The car is not going to allow you to engage 6th gear until you are at a certain speed, so the engine doesn't rev too low. Go up over 50 and I'm sure you'll be able to push it to 6th.
Accord, stick
What year?
All current gen of auto Optimas are 6 speed. Problem with manumatic shifting is that car does not allow you to shift higher if you are not going fast enough. During test drive I had to go 70+km/h in order to shift into 6th and see it on the display. Kind of dumb; if there is a shift lever then let me decide which gear I want to be so I find this manumatic shifting a joke.
6th only available above 42-43 mph when Auto shifting...........
What year?
no it isn't why would you want to shift to a higher gear if its going to lug, you wouldn't do that with a regular manual shift! The 6th is 0.772 gear ratio.
Cerato S Hatch Auto
In addition to putting sensible limits on gear selection, most "manumatics" will select 1st gear automatically when you stop. It's a safety precaution so you will have motive power after a panic stop, for example.
I've only used manual shift on our Cerato 6-speed auto a couple of times, mostly to confirm that it's working. Also useful in hilly country, but not really essential unless you're tackling a long descent.
the manual shift is very helpful in snow conditions, particular when slowing down at a stop, I let the engine do it rather than the brakes. Also when taking off in snow, use 2nd gear - all tips I used when I used to drive regular manuals. But probably 99% of the time is only used in the regular automatic mode. It's a nice compromise.
1 - 7 of 7 Posts
