Can a simple swap be done with a 2012 Base 15" with 2012 Exclaim 18" Wheels? (I have a M/T btw.)
If so, are there any adjustments that need to be made after wards?
(ie. speedometer reset, brake upgrade, suspension upgrade, calipers, couplings, etc?)
Will MPG change since the Exclaim is rated the same MPG as the BASE?
Also, I was thinking of maybe a 17" for a smoother ride than a 18". I used a calculator (http://www.miata.net/cgi-bin/tirescgi) and found that a 17" tire that comes the closest to the stock exclaim 18" diameter is a 215/55R17.
Will this work too?
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
235/45-18 4.2in 13.2in 26.3in 82.7in 766 0.0%
215/55-17 4.7in 13.2in 26.3in 82.7in 767 -0.1%
Thanks!
I don't see why not. I just purchased a 2013 Soul Plus with a MT that comes with 16" stock wheels and I literally drove it home from the dealer and replaced the wheels/tires with an aftermarket set. Wheels are 17", tires are 225/50R17. I don't know if the change in size has affected speedometer or mileage etc. but other than than that it's a simple swap.
A little bit of both. I wanted a little lower and wider and they gave me the options. Rides nice and seems to handle fairly well considering I typically drive sports cars. I didn't want to go too low and have a rough ride.
I still wonder though since I have the Base model 1.6 vs Plus 2.0, the engines are different. So what if the suspension, brakes, calipers, etc are also different to accomodate the larger wheel sizes avail to the Plus or Exclaim models.
