1 - 8 of 8 Posts
2001 KIA SPORTAGE 2WD
Have 2001 Sportage with 138000 miles on her, been a great vehicle & reliable. It starting running really sluggish, check engine light will flash at higher rpm`s, codes showed misfiring on all cylinders. Replaced plugs,wires,& coils; same problem. Friend put it on diagnostic machine at his father`s shop & told me the Ignition misfire sensor was bad. Checked online & all the parts houses sell them, so got one from Rock Auto, but don`t have a clue where it`s located, can`t find any info on the web (except the part for sale), friends Dad`s shop doesn`t work on imports so they had no clue.
Anybody know where it might be so I can get her fixed & running smooth again?
Thank You
Caribou, Otter, Buffalo
You are being misled... what exactly do you have?
Is is a knock sensor, or a CAM angle sensor?
OR!
Not having worked on imports is a poor excuse, as all engines work the same, especially OBDII compliant
... Philip
What diagnostics have you run??
Verified engine timing (static)?
Verified CAT not collapsed??
Verified fuel pressure up to spec???
Verified Vacuum is 19-21hg" at idle????
Run the basic OBDII diagnostic tests?????
Please list the particulars of the engine... Philip
Greetings,
You stated you got the part from RockAuto -
posting the Brand/Name/Part # of the item purchased may help us to point you to the part location,
Regards,
GottaCruise
2001 KIA SPORTAGE 2.0L L4 : Ignition : Ignition Misfire Sensor Price
STANDARD MOTOR PRODUCTS Part # AS239 {Click Info Link for Alternate/OEM Part Numbers} Intermotor; Blade Terminals; Terminal Gender: Male; Direct OE Replacement; Number of Terminals: 3; Mounting Location: External; Connector Gender: Female
This is from Rock Auto
And this is from O`Rileys
BWD - Ignition Misfire Sensor
Part # EC7000
Line: BWD
Ok, thanks for the part #'s ..
I checked as best I could, did not find those parts being applicable to the 2001 Kia Sportage - closest match I found was for the 1.8 Kia Sephia motor, cross-referenced by (KIA OEM) part # from RockAuto, via (google)..
+1 and agree w/ Philip: (multiple) misfire codes present generally indicates a (physical / mechanical) issue, and -not- a sensor issue,
Causes of multiple misfire include failed pre-Cat. converter / restriction in exhaust system,
Incorrect physical (static) timing / jumped or failing timing belt,
I would check w/ your friend, and see what the -exact- OBDII DTC codes were, that may help, if in-fact a sensor issue,
* But would advise to check static timing and exhaust for restriction also - driving with a blocked pre-Cat converter can/will eventually overheat -> damage the motor ..
If unable to get the DTC codes, consider purchasing a low-cost ODBII Data Scanner, so you can read the codes and view real-time parameters from the ECM (laptop/USB example in my sig.)
Regards,
GottaCruise
Discussion Starter #7
Thank You for the info. I had to replace the battery this morning, so bought a ODBII reader also(don`t own laptop, or I would have gotten the Data Scanner for sure). Check engine light came on within the first mile, pulled over and checked for code,PO303, engine misfiring on cylinder 3. Now I`m really confused, as it went from multiple codes to just this one. Guess I`ll make sure plug is gapped properly & check spark plug wire.
Thank You again, guess I got took on buying the sensor.
Would also recommend checking the short HT lead on that coil pack ( 2/3 ) - there should be a resistor in-line on the short lead, and it should measure approx. 5k Ohm resistance (4.9 - 5.1 range) ,
Spark plug wire #3 should measure approx. 3k Ohms, IIRC ..
* Since you have already serviced plugs/wires, you probably know about the short pigtail lead that connects to the back motor <-> the coil packs: any cracking on the coil pack connector ends or visible wear or oil on the pigtail lead, recommend (replacing it),
Any oil at the spark plug wells s/b soaked up w/ paper towels before removing the spark plug, if oil is present, consider any plugs / wires badly coated w/ oil suspect, and provision to check both coil packs and to replace the valve cover gasket ... (Common issue w/ Sporty 2.0L motors leaking oil into plug wells #3 and #4 ..)
Best wishes for a speedy repair,
GottaCruise
1 - 8 of 8 Posts
