kia sedona 2.9tdi 01, isuzui trooper 3.1td, Transit 2.4 2000
Hi, Having a fault on my sedona, engine pre-heat has stopped working. No glow light coming on on dash when key is turned on. Any help please.
Banned
If you stand in front of the car with the bonnet up and follow the thick black hose from the intercooler to the inlet manifold, you should see 2 wires going to terminals on the aluminum block that the hose from intercooler joins to. Check the wires are not loose or broken, this is a common fault on these cars:eek:
