Hi All, This si my problem. I Have a Sedona 04 and suddenlly it dies, after 20-30 minutes it started again but stallin. The scanner read p0340 (camsahft position sensor "A"), I bought a new one an installed, then start fine, smooth and plenty of power but 4-5 minutes later start stalling and dies again. I've tested the wiring from CMPS to ECU and everithing is normal, and yesterday I finally changed the ECU, and the same problem and the same code is set. Can any one Help with iddeas on what to do???????? Thanks to all
1999 Hyundai Elantra Wagon, 2003 Kia Sedona, 2012 Kia Sedona, 2007 Hyundai Tucson
If it was my car, I'd be replacing the CAM sensor at this point. Cam and Crank sensor work in conjunction, and if they disagree it can mean it's really the other which is the problem. Just a wild guess, however. Make sure the timing belt is good too.
