2013 Sorento SX AWD prem pkg
Has anyone encountered and found a solution to the screen lighting at night when Sat radio (SiriusXM) is selected? The rest of the dash dims nicely but the radio display is so bright it is makes night vision difficult. Read the manual numerous times but have not found a way to dim it and usually switch to Nav (does darken at night) to see even when not using NAV. It is somewhat of a safety issue. Especially bothersome away from city lights on very dark roads.
Curious if anyone else has found a solution other than switching the display to NAV or covering the display with paper, lifting it to change channel. yeah, tried that to.
Thanks.
White 2012 SX AWD
you can turn the display off. that works quite nicely at night.
the controls and everything works as normal. when switching to other modes, the display comes back on.
I believe it's in settings...don't remember but should be easy to find.
2011 XM Sorento EX AWD V6
Hey Rick,
There is an old string on this but to make it easy for you, switching to NAV or switching off display were the only solutions.
I went into the display settings and moved the brightness all the way to low permanently and it does little.
Good luck.
