1 - 11 of 11 Posts
2017 Kia Sorento EX
I’ve got a 2017 Kia Sorento EX and I just installed aftermarket running boards......I understand that the mud flaps need to be altered to put back on......can anyone give me any advice on where to cut or how to measure where I need to cut. Also like in the pic below someone posted that there’s a screw missing to make the running board flush with the body, but I don’t have a whole there to put a screw in.......any advice or help is appreciated.
RoadSport 4754 'B' Series Premier Splashguards
I installed those running boards and what I had to use for the front flaps was some flaps I bought off of Amazon (I tried to make the KIA front flaps work by cutting them out but it was a waste of flaps and time). Anyhow, here is what I used, RoadSport 4754 'B' Series Premier Splashguards. They turned out looking like factory OEM and will conform to the arc of the wheel well and front flat end of the running boards perfectly. I will take some pictures if you want.
2017 Kia Sorento EX
Thank you for the response and info.....and yes some pics would be great!!
Here are the pictures. If you look close you will notice that I cut off about 1" of the inboard side of the flap, otherwise it would have been to wide for the best fit. There are other things also that you need to do for a better fit of not only the flaps but the running boards themselves (specifically the front tip portion of the running board to make it pull up flush to the bottom of the vehicle). Any questions let me know.
2017 Kia Sorento EX
Thank you......I’ve got some ordered.....I’ll let you know how it turns out.
Sorento FL Diesel 2.2
Cut my original (non-GT) mud flaps
Hi, refer to the pics attached. As my car came with original mud flaps I had to remove the front mud flaps when I got the running board / side step installed. Subsequently I had my ori mud flaps cut (by using a blade) and got it installed back :D
2017 Kia Sorento EX
Discussion Starter #7
Did you have to cut all the way through the mud flaps to get them to work? Could you possibly take a close up pic of the front and back of the mud flap so I can get a better idea of what I need to do. Thanks
I just purchased some Black Horse running boards for my 2017 Sedona which came with useless instruction instructions. Looking under the car there is a large plastic panel covering the entire bottom. Anyone have any tips for removing this before I start?
Thanks - Brad
Thanks - Brad
eg.
USA
UPDATE: Vehicle Information
Forum Rules
2016 Kia Sorento SX AWD
Could someone with these running boards post pictures from a side wide view? Would love to see how the Sorento looks like with them installed. Thanks!
1 - 11 of 11 Posts
