Rough Start after rain
12700 Views 3 Replies 3 Participants Last post by  jcwit
Hi everyone. So I have a 2003 Kia Rio with about 125000 miles on, living in northern Illinois. Over the past 3 months or so after heavy rain my kia has a really rough start. The car shakes as if youre going over a speed bump or if you have been in se Asia driving on the gravel/dirt roads. The engine bay looks moist and I think that might be the problem, something getting wet? I let it run/warm up a bit and then shut it off. After 10 mins or so I start it back up and its fine. Just wondering if anyone has had this problem or any ideas on how to fix it. When warming up, it shakes as described until I rev it to a little over 1k and then it feels normal until the rpms go back down. Thanks in advance!
RIOs around your model year have problems with the low voltage plugs that connect to the coil packs (ignition coils. They become brittle and fall apart.
Spark plug wires as well as the coils break down over time and moisture on either can cause misfires from the high voltage jumping from them to ground..
Another "problem" is the IAC (idle air control) valve on the throttle body..It gets gummed up with oil and soot. If it can't constantly readjust the idle throttle the engine either sticks at high RPM or stalls... If you look inside the throat of the throttle body (take off big rubber air hose) and see black soot on insides and on butterfly valve (round metal disk) clean it with choke and carb cleaner and a solft toothbrush and cotton cloth. The IAC is external and makes a buzzing sound with the ignition on and engine NOT started. It may also need cleaning.
Take some time to read the past threads in the RIO section as there is a wealth of information there...
Thanks for the info. Like I said, this only happened after the rain. The closest thread I found was the weak battery after raining thread. So I thought I could post the question. Anyways thanks for the info.
Another problem is condensation from under the engine cover and getting the ignition wires causing misfiring. Get the engine up to full temp so as to dry the wires fully then turn engine off and spray wires with silicone spray. This will seal them, curing the problem if is fact this is the problem.
