After 20,000KM this issue with our jerky takeoffs is getting past the point of amusement. The throttle basically falls away when it's not meant to and the thing bogs down and jerks on takeoff. From my extensive thinking, i've narrowed it down to what has to be one of the throttle cut-out switches.
can someone tell me:
1) is there a cutout switch for every pedal? as in clutch, brake and throttle itself?
2) is there a fuse to pull, or easy way of disabling the switches on each pedal to isolate if that's the problem?
3) does disabling these switches have any detrimental effect? other than cruise control that is
also does anyone have a link to a workshop manual for this thing? need to check the TPS too.
