Just wondering, where is the spark plugs located on the 2012 Rio Sedan? When I open the hood I don't see the typical spark plugs and the wiring harness that connects to the distb cap.
YOU FIRST HAVE TO REMOVE THE PLASTIC ENGINE COVER. You will see four coil packs.
They are clipped onto the plugs. Ther plug attached the coil pack has a slide lock that must be released to remove the coil pack wires. No distributor or traditional plug wires.
