Nice to find a forum for my car. I have a burned out drivers-side headlight. It seems simple enough to replace in the manual but the space around the cover is so congested that I cannot get at it. Does anyone know what you have to remove (how many things?) before you can actually get at that light better.
I have a 2002 Rio RS.
Thanks,
Robin
2004 Kia Optima
Thanks,
Robin
Check this site out: http://www.luminicsbulbs.com/KIA/Rio/2002/
Your lights are H4's. Hope that helps! :thumbsup:
Otherwise you can always pick up a set of Sylvania Silverstars... $36.88 @ Advance Autoparts.
FYI: I know you said that your drivers side only burnt out.. but you should replace BOTH lights if possible.
Much easier to remove the light unit, take out the bolts you can see, then lamp unit pulls out, bit tough as it's on a ball joint.
