I just replaced the entire ignition lock. When I turn the key to on, everything works fine. Once I start the car and it is running, the headlights, blower, wipers, clock, etc. no longer work. Did I overlook something? Any advice?
I will mention that I managed to destroy the cable clock spring in the process of removing the steering wheel, but that should only affect the airbag, horn and radio controls on the wheel, correct?
Discussion Starter #2
I have solved the issue. Sorry for the post. If a mod thinks this might help others, leave it. Otherwise delete at your discretion.
The issue was with the new ignition switch. When I start the car and release the key, it doesn't spring back to the "on" position. It stays stuck just slightly ahead. I simply need to turn the key about a degree or two back, and everything works fine.
eg.
USA
UPDATE: Vehicle Information
Forum Rules
