Hi everybody !
Does anybody know how to remove the rear light assy on 2002 Rio RX-V?
When you open the back door you see two screws only holding the light assy. You remove them, but the light assy does not come out, and it seems that the light assy is fixed at its other end (close to the body).
Any help will be appreciated.
Thanks.
If it is the same as the sephia, which it sounds it is, try to slide the assembly to the outside of the car, there is a little slide before you can pull out the knob that holds it in place.
