Its me again, we are still having problems finding clearence for the alternator to come out, so we thought we would try by pulling the axle. But it seems it will not come lose, we got all bolts etc remove, but it wont disconnect, tried prying etc.....How do you do this?
Discussion Starter · #2 ·
okay well to update this.......
we finally got that off, and the alternator still will not come out the bottom, i dont understand how to get this out....someone please help...
When I was replacing the engine in my '02 Spectra with 1.8L DOHC, I put in the motor without the alternator. After the motor was set and motor mounts connected, I discovered there was not enough clearance to get the alternator in. I loosened the motor mount nearest the belts, raised that side of the engine some, and was able to get enough room to wrestle the alternator in.
Hope this helps.
Mark in MA
