Rear Windshield Washer Tank?
745 Views 5 Replies 4 Participants Last post by  rhartmaier
In the 2016 Sorento LX with V6 is there a rear washer tank to add fluid to
or just the one under the hood in the front. Seems I'm going through about
a gallon a month using both front and rear washer/wipers. I've checked and
no leaking that I can see.
Thanks in advance!
Just the one under the hood feeds both, unless I have one for the rear that has been secretly defying physics! But it does sound like a lot of use, have you looked directly at the tank/pump/etc? I think we've seen a couple of leaks here.
Yea and no signs of any leakage. It has been a snow/slush/sleet winter so far.
I go through a lot too. I think it's because it's a big tank and a good amount comes out on both sides. I can find myself filling up a gallon and still not be enough. Probably depends on how long you pull/push and release the wiper on the stalk.The back one comes streaming out pretty good. I put in de-icer around November before the freeze so the fluid and the line that carries it can keep on fuctioning.
  • Like
Reactions: 2
Update (May 2023) while mechanic had car on lift for brake work he noticed a cracked
plastic piece on the washer fluid pump. He replaced it and now a much stronger fluid stream
and more importantly no leaking.
  • Like
Reactions: 1
Good catch! I only use about a gallon a year, but then my car is parked for two months during the winter when my wife and I escape to warmer climes.
  • Like
Reactions: 1
