2013 Kia sorento ex
Neither the fob or soft bottom will not open the rear power lift. I have to crawl in the back and manually open. Note: There is no open or on off switch on the console.
Tried
Changed battery in key fob opens all doors except rear tailgate. No nose heard at unlock
Tried to open in neutral and park
Soft button on outside door does not work either
Checked fuses in panel appear good.
Need help. Any suggestions! ?!
Neither the fob or soft bottom will not open the rear power lift. I have to crawl in the back and manually open. Note: There is no open or on off switch on the console. If you want to find the best pex crimp tool, visit AutoGuysLand to review before getting one.
Tried
You can try to check entire latch mechanism. It could be the issue.
