Hi Guys,
I wonder if anyone can help me or has had this issue before...
I release for the rear hatch window was working fine from both the key fob and from the driver door button and then all of a sudden both buttons now fail to release the rear hatch window.
All the other electrics seem to be working fine, from lights through to heated seats and air-con. I have tried to check for a fuse problem, but I cant seem to find out which fuse I would need to change out, and have a check over the fuses I can't seem to find a blown one.
It can't be the fob batteries as the fob opens the other doors and the driver door button also fails to release the hatch.
Has anyone else has this problem in the past?
Thanks in advance
John
Model: 2006 Sorento XS
Thanks Gee6,
I took the trim off around that part of the tailgate and the wires all seemed ok, although they are in a loom with cable ties so it’s hard to say.
Do you have any idea with cable in the loom I should be looking for?
Thanks
John
