I have a 2002 Kia Sportage with a light on that says my rear hatch is open, but I have made sure it is completely closed. I can't get the light to go off and this problem is draining my battery. I took the panel off of the rear hatch and looked at the latch. It looks fine. The door opens and closes just fine. I can't find a fuse to remove to get this to stop. I tried disconnecting the wire running from the lock to the rest of my rear wires and that didn't do anything either. Does anyone have any ideas of how I can resolve this problem? I'm having to disconnect my battery cable to keep my battery from going dead. Thanks
2000 Sportage A/T 4X4
It will be better to remove the latch, you'll see a switch, maybe it's stuck with debris, clean or change it if necessary. You can also remove the lamp, but it will be difficult to see at night in the compartment area.
Do I have to take the entire handle and latch mechanism off? I took the back panel off of the door and I sprayed some carb cleaner all over the mechanism inside of the latch. I removed the screws on the side of the door and got spray in all of the areas and cleaned off as much as I could without completely taking it out. When you say remove the lamp are you meaning the lamp for the dashboard or something else? Thanks
2000 Sportage EX 4x4 A/T, 2008 Harley Davidson Nightrain
I beleve he is talking about the door switch (sounds like it's faulty). It should be a push button syle switch with a rubber boot on it that controls the light (just like on all your other doors). Otherwise you can remove the cargo area light bulb until you track the problem down.
1st gen sportage has a recall issue with the rear hatch; same as mine. But it's a no big deal for me, i just used to it. just ignore.
Can you take it to a Kia dealership where they have trained technicians to look at your issue?
I always gravitate to calling or visiting the dealership as I learned it the hard way. I used to own a used Honda Civic and when troubles started, hubby took it to a self-employed technician and it went downhill from there (with so many visits to the same technician).
