I have 2006 and I'm having an issue with the driver's side passenger sliding door. This is not a powered door; simply a manual opener.
The door is behaving like the fuel filler door is open. It will unlatch and slide ~1". The fuel filler door is working properly, as is the lock and latch on the sliding door.
I know there's a mechanical catch that prevents this door from opening when the fuel filler door is open. Does anyone know how to access it? Will I need to replace parts or is this something I can simply disable?
Thanks!
2007 Kia Sedona Ex
Rear auto door opener broke
I'm having an issue with my rear door. It is an auto open door. The bracket that lifts the door in automatic mode came off. One screw backed out and the other broke off. My problem is getting the trim piece off so I can screw the bracket back on. In the image I turned the trim piece so I could shut the door. I put the screw that backed out in a safe place that I can't remember where it is. I'm looking for a part number or size of the screws for the bracket on the power lift.
