1 - 7 of 7 Posts
2002 Kia Rio Wagon
Probably a super simple question but... Can someone tell me what exact part I need to connect a Pioneer AVH-280BT radio to an 02 rio? Note, I have just the radio and not the radio wiring harness. Current radio in the rio is factory.
Thanks!
2014 Hyundai Veloster Turbo / 2001 Kia Rio
2002 Kia Rio Wagon
Discussion Starter #3 (Edited)
So I tried to instal an aftermarket radio. All went well. However when I went to slide in the radio I pulled the yellow wire from the butt connector as the power was on. Now the radio will not work. I put the factory radio back in and that will not work either. I hold the power button and it makes a beeping noise. When I turn on my headlights the beeping noise starts up as well. Dome lights do not work either. Wth did I do? lol The fuse Under the dash is fine. Car runs fine other than what was stated above.
2002 rio cinco
sounds like its grounded out.
is there an inline fuse in the radio harness?
did you check the fuses in the engine bay, drivers side?
Drives : Nissan NV200 Flies : Rans S6ES
The radio memory/dome light fuse is this one out on the engine bay fusebox. It's usually fitted in a yellow fuse carrier that is missing in the photo...
114605
2002 Kia Rio Wagon
Discussion Starter #6
Absolutely brilliant- thank you! That was the issue. I was looking for something that said radio like it does u see the dash. Much appreciated.
1 - 7 of 7 Posts
