I have a 2012 Sorento and want to pull a small pop up. While looking under the rear end to see if the bolt holes for the hitch were there I found two plugs attached to the frame under the left tail light. Are these two plugs for my trailer wire harness?
2011 Kia Sorento, 08 Toyota Tundra, 1956 VW Manx buggy, 1958 VW rail
trailer towing wiring
You need to find out from someone if there is built in to the sorento, a converter(diodes) so your sorento 5 wire tail, brake,turn, stop and ground matches the 4 wire trailer plug. i tried to wire in a converter and it never worked right. the tail lights would turn off for 5 seconds then come back on for 5 seconds. good luck.
Thanks guys, I actually found a wire harness on etrailer that has the converter built into the harness. They also had a video showing how to install, very easy. Thanks for your help..
